When I had android 11 it worked perfectly. I also had syncthing installed on win10 and it synced folders and files perfectly.
Now that I have android 12 installed I can’t sync because the devices don’t see each other.
How can I fix this?
Please make sure your network in Windows 10 is set to “private” and not “public”, or otherwise it won’t allow any direct connections, meaning that Syncthing will only be able to connect through a relay. Also, just for testing, if you have disabled relays too, please try to re-enable them and see what happens. Lastly, if that doesn’t help and the devices still can’t connect, you can try to simply hard-code the IP addresses.
