File <here_is_id_of_syncthing_container>-json.log just increases size dramatically, it was 117GB, I removed it manually and see that after 1-2 minutes it is already 75MB.
How can I decrease size of this log or turn off it? Or setup limit for size?
The web GUI contains a Global Changes button under the device list which displays changes since the last (re)start of Syncthing. With the -audit option you can enable a persistent, detailed log of changes and most activities, which contains a JSON formatted sequence of events in the ~/.config/syncthing/audit-_date_-_time_.log file.
And according to description FAQ — Syncthing documentation should be json log file ~/.config/syncthing/audit-_date_-_time_.log but I have only one log file
Also, I have tried to add options to containers: ‘-logfile=-’ ‘-logflags=0’ but did not help and I do not see any information in FAQ — Syncthing documentation about size limitation of log file, it is stupid, because each soft has it.
On windows 10 I use SyncTrayzor and there is option for log file and my syncthing.log ~ 127KB
This looks like docker creates this file to capture the console output of the container. The audit setting would also cause higher writes to the console so this is somewhat expected.
I don’t think this does what you think it does. Sure, this deletes the file from the filesystem so it’s inaccessible, but it will still consume space if it’s open and being written to.
You need to modify your docker setup not to launch syncthing with audit flag.
I have no idea, I am not familiar with whatever system is being displayed in your screenshots.
Based on the flags it should not produce audit logs, but perhaps you have some debugging environment variables set that increase the amount of logs syncthing produces.
I’d check the actual content of the logs and see what it contains.
If you really know you can show me how to stop audit log in docker compose file or any other options, let`s imagine that I do not have Portainer.
The problem is not in my setup, problem that nobody knows where is audit log setup and how to stop it, but a few persons mentioned it… Strange to hear that from ’ Syncthing Maintainer’ members
I don’t see anything here to indicate this is audit related. Or possibly even Syncthing related. But as mentioned, why not take a look at the log in question instead of laughing at the people trying to help.
Ok, I was wrong, do not pay attention to my mood, sorry if I offended you, issue related to docker container itself, by default Syncthing will be created with full log.
I would add –log-driver none or local for documentation OR if someone uses Portainer there is simple option on UI
