Hi
first time I use this feature (almost a year after !)
But having already configured the Reverse Proxy Setup for the apache server, when I check the “Use HTTPS for GUI” the apache setup breaks.
I modified it a bit so it works:
LoadModule ssl_module modules/mod_ssl.so
SSLProxyEngine On
SSLCertificateFile /path-to/.config/syncthing/https-cert.pem
SSLCertificateKeyFile /path-to/.config/syncthing/https-key.pem
ProxyPass /syncthing/ https://127.0.0.1:8080/
<Location /syncthing/>
ProxyPassReverse https://127.0.0.1:8080/
#Require all granted - not for apache v2.2.15
Allow from all
</Location>
Now when I hit http://server-ip/syncthing/ I can see syncthing’s web gui, but having no https indicator…
Since I am just a newbie, is this configuration correct and also secure?
