new to syncthing, we investigate the tool to help a colleague having exactly same folder at home and at the office, for example for both Desktop and Document folder.
As far as I understand the tool and the UI, this is not possible as we need to create a dedicated folder.
How to sync /home/me/Desktop folder on both machines ?
Sorry if I missed the dedicated section of the documentation and thanks a lot for the tool and support.
Ummm…. This is exactly what Syncthing does. Please read Getting Started — Syncthing documentation and experiment a bit using a test directory. If things does not work out for you, please come back with specific questions.
I use robocopy and its counterpart in other OSes for local transfer. X-Plore for android. Robocopy for backup. Rsync also is possible. Cloud alt:foldersync.
Hm, syncthing takes any folder. As long as its not looping, I misread it. But theres no problem with existing folder using GUI. I’m trying to use one folder as Martchus suggests, but technically storage/emulated/0/DCIM
/Android/media are possible tho .stfolder always disappear periodically. As long as its not immutable folders like Android/data
I get OP question now. You’re gonna make a loop in syncthing. Its not made for that. Use robocopy for that. Tho looping the sync directory sounds dangerous.
Edit 2
Wait no both Documents and Desktop are under C\Users\computer_username(User)\
It’s not looping. Could you copy paste your directories here? Obfuscation with leetspeak is fine.
