Great. Which folders? Where is the config stored, including all the devices I want to get rid of? I looked where I downloaded the mac version from, could not find any config file in it, so am guessing there are stored somewhere outside of this (Library, home dir?)
Unfortunately, how to uninstall is missing from the user guides.
I think you mis-understand. I dont want to delete the folders, I want to uninstall syncthing. I have tens of thousands of errors trying to download the shared folder (so it fails), and want to start again with one one devices sharing (currently I have 80+ as I used introducer). So I want to get rid of every trace of syncthing, especially the list of devices. Deleting them one by one is very slow. I have been unable to find where syncthing keeps its config.
If you installed it using brew, brew probably has a way to uninstall it. You haven’t explained how you installed in the first place. You can probably run syncthing -paths and delete the config and database directories.
In installed by downloading the official mac version from syncthing site. Its a zip file which I uncompressed and run the syncthing executable.
Brew is not really an option as I need to document a way to install and configure syncthing without using terminal/unix for the Mac users who don’t know what terminal is (sales/marketing etc)
