In short:
Is it possible with ST to share a whole folder and sub-folders of that folder in two different shares? If so, how?
Long description:
I have a huge folder (C:\huge_folder) which is shared completely (no .ignore file) to some clients (CLIENTS-A) als SHARE-A.
Now I want to share some few folders from that huge folder within a new share, say NEW-SHARE-B to other clients (CLIENTS-B).
I tried with the .ignore file, but unfortunately the ignore-file from SHARE-A (which is in C:\huge_folder) is overwritten with the content from the ignore-file from NEW-SHARE-B (which is in C:\huge_folder\ too), and this is not desired.
Any Idea, how this could be accomplished?
master computer:
SHARE-A:
C:\huge_folder\
CLIENTS-A should receive:
SHARE-A
CLIENTS-B should receive:
NEW-SHARE-B (C:\huge_folder\subfolder1
C:\huge_folder\subfolder2
C:\huge_folder\subfolder3\subfolder1
ā¦)
Hope, I was clear enough.
Thank you, for your ideas.
P.S.
CLIENTS-A are trustworthy
CLIENTS-B are not (which means, I donāt want them to see any other folder/file besides in NEW-SHARE-B)
My solution for something like this are bind mounts, but that doesnāt exist in Windows.
Using symlinks also doesnāt work, as Syncthing currently does not follow them, see:
The only working (but ugly) solution I can think of for Windows would be to share each sub folder as its own Syncthing folder to CLIENTS-B or split the huge folder into 2 and share both with CLIENTS-A and only one with CLIENTS-B.
In the future, the ignores will probably be stored in the config not inside a file, so your initial idea would work.
Moving a Level up will not work, as SHARE-A is the top-level/root and changing the folder-structure isnāt possible as other software relies on that specific path(s).
ā¦mount bind is a nice idea and would work if a linux-client would be a master, but unfortunately, the linux client is a slave.
Anyways, it was a trial, and Iāll wait and monitor, meanwhile, we can use symlink-friendly-sync-software to achieve the goal.
