How to readd folder
Is there a way to readd a folder shared from a remote device?
  • I add folder F from remote device A in device B
  • Then removed it from B
  • Now I want to add it again in B
To do it now I go to A and disable the shared folder, then enable it again to have the window to add the folder F in B. Isn’t there a way to do it directly in B?
Thanks in advance, I hope I’ve been clear.
You should see an “Add Folder” pop-up in the Web GUI if you reset the connection, e.g. by pausing and unpausing the other device.
Thanks, that’s not intuitive but it works!
