So, I wasn’t very carfull and right after running syncthing in my MAC OS, I started to change the GUI to what I was tought was I needed and now after I run the Syncthing, it just wont apear any GUI.
[QX5QL] 14:39:14 INFO: My ID: XXXXXXXXXXXXXXXX
[QX5QL] 14:39:15 INFO: Single thread SHA256 performance is 518 MB/s using minio/sha256-simd (448 MB/s using crypto/sha256).
[QX5QL] 14:39:16 INFO: Hashing performance with weak hash is 428.95 MB/s
[QX5QL] 14:39:16 INFO: Hashing performance without weak hash is 506.52 MB/s
[QX5QL] 14:39:16 INFO: Weak hash enabled, as it has an acceptable performance impact.
[QX5QL] 14:39:16 INFO: Ready to synchronize "RS12TB" (tunpr-n7efh) (readonly)
[QX5QL] 14:39:16 INFO: Send rate is unlimited, receive rate is unlimited
[QX5QL] 14:39:16 INFO: Rate limits do not apply to LAN connections
[QX5QL] 14:39:16 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
[QX5QL] 14:39:16 INFO: TCP listener ([::]:22000) starting
[QX5QL] 14:39:16 INFO: Completed initial scan of readonly folder "RS12TB" (tunpr-n7efh)
[QX5QL] 14:39:16 INFO: Device XXXXXXXXXXXXXXXX is "Andres-iMac.local" at [dynamic]
[QX5QL] 14:39:16 FATAL: Starting API/GUI: listen tcp 42.235.49.777:5006: bind: can't assign requested address
[monitor] 14:39:16 INFO: Syncthing exited: exit status 1
[monitor] 14:39:17 WARNING: 4 restarts in 12.533607958s; not retrying further
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
Can i get any help in how to reset all of this?
Sorry for my english.
