Some people don’t need connection infos in the device header, e.g. if all devices are inside LAN. To hide the icons you can use this simple hack
- create a new theme
- add css to theme.css
@import "../../theme-assets/light/assets/css/theme.css";
.reception {
display: none
- restart Syncthing and select your theme from settings
- if you only want to style certain icons, e.g. disconnected, change to
.reception-0 {
display: none
reception-4 … TCP LAN
reception-3 … TCP WAN
reception-2 … QUIC
reception-1 … relay
reception-0 … disconnected
