I have many devices running Syncthing, mostly all sharing the same folders.
My problem is that, despite having inotify enabled and fsWatcherDelayS=“1”, sometimes I change a file right before shutting down a computer, so the change is not picked up and propagated to the other devices, leading to problems, conflicts etc.
Now, I could open the web gui to check, but I’d prefer to simply write a script that waits for the changes to be propagated before shutting down. Alternatively, having something like a shell script or tray icon that informs me of when the changes have been propagated would work.
I’ve looked into the API (and use some API calls in my scripts), but understanding if changes have been propagated to other devices seems harder, i.e. not baked in the API but something I should build by parsing log messages.
Any suggestions?
Thanks in advance!
