How to delete ignored files in syncthing (unofficial, with caveats)
So, this is a technique I’ve been using for some years now. I’m posting this here because it appears that this is asked quite frequently, so I wanted to at least document it.
This shows how I automatically delete ignored files. A typical example are cache/temp files: Originally I forgot to ignore them, so they synced. Then I ignored them, but I still have old cache files laying around I want gone.
Disclaimer: This technique is not officially supported and not without caveats. There is a risk of loosing data if you don’t know what you’re doing. You have been warned.
To better explain the situation, lets make some assumptions about the setup. This technique also works in various different setups, but I believe that showcasing an example is much easier to understand.
Setup: Three devices (“PC”, “Laptop”, “Server”) that all share a single folder.
Situation: Some files have been ignored on “PC”, but they have already synced to “Laptop” and “Server”.
Goal: Automatically delete the files on devices “Server” and “Laptop” that have been ignored on “PC”.
initial
Imagine the above folder layout. Three normal files are there, and two files that should be ignored. Those have already been ignored on “PC”. However, they are already synced to the other devices and are now lingering around. The Global state on all devices hence looks like this:
global-state-before
Prerequisite: All devices are online and up-to-date. I highly recommend to not change any files during this process - if you’re not careful, those changes can get lost.
Step 1: For safety we’re going to flip “PC” to send-only. This allows us to undo accidental deletions if something goes wrong. However, changes from “Server” and “Laptop” won’t be received during this period.
Step 2: Ignore the to-be-deleted files on both “Server” and “Laptop”. If done correctly, the global state will drop down by the number of ignored files (and folders) to indicate that the ignored files are not valid anywhere.
global-state-reduced
In the above screenshot, we see that the global state has dropped from 5 to 3, because the two ignored files are now ignored everywhere.
Step 3: Flip the folder type on “Server” and “Laptop” to Receive-only, if they aren’t already. This is important, because we’re going to rely on the revert local changes feature for deletion.
Step 4: With the folders still in Receive-only, remove the ignore patterns from “Server” and “Laptop”. If you only want to delete a portion of the files, only remove the ignore patterns for the files you want to delete.
local-additions-are-previously-ignored-files
Note how the local state is now larger than the global state, because this node has un-ignored files that are ignored everywhere else. Because it’s in receive-only, it won’t send out the “changes” we made to the ignored files.
Step 5: The previously-ignored files will now show up as “Local Additions”. You can click on “locally changed items” to view them. In our setup, this will show the two ignored_file_{1,2}.mkv files. Ensure that everything is okay and you really want those files gone.
Step 6: Press the big red “Revert Local Changes” button shown above. This will delete the ignored files.
If the ignored files are deleted (local state drops down to the global state), all is good! You have succesfully deleted the ignored files/folders.
Troubleshooting note: I have encountered cases where pressing “Revert Local Changes” did not delete any files. Instead, the local state jumped back up the global state as if nothing happened. I believe that this is a bug in syncthing. In such cases, I had to perform an index exchange first: This can be done by removing the folder on any device and then readding it (with the same path, ID & settings). Alternatively, you can try starting syncthing with --reset-deltas command line option on any device.
Afterwards, once the folder has scanned and synced everywhere. Try “Revert Local Changes” again. Now the files should be deleted.
Step 7: Once everything has been deleted, revert all folders back to their original settings (send-receive for example) and restore the proper ignore patterns. Sync now continues as usual.
fyi this does not work at all as of 10/26/25 using syncthing 1.29.2. It starts out fine, but when the “receive only” folder finishes its scan it suddenly sees the global state at roughly twice the correct value, or sometimes simply whatever it was before. the option to revert local changes appears, but has incorrect values and does not actually work anyway. i tried --reset-deltas, and completely unsharing the source read-only folder while removing at remote devices, and nothing worked but just deleting all files/folders on the receiving side at the filesystem level and re-syncing. was fine bc it was all over my LAN, but no variation of this was anything other than a waste of time.
seems like it probably used to work, and it certainly should. but it doesn’t.
Just finished this guide and it worked like a charm!
My setup devices looked a lot like the example, except that I only wanted the ignored files deleted on the server (a raspi nas with an usb ssd), and keep the newly ignored files on the desktop and laptop. I had been using syncthing between the tree devices on my entire Documents folder without any ignore files, leading to sync conflicts within .git and in project build files, and to python .venv directories being synced.
I made a .stignore-global file that I #include in the normal .stignore file on all devices. Because .stignore-global itself is not ignored, this allows me to have a global set of ignore rules that are automatically synced and imported on all devices, though you do need to manually set up the #include on each device.
To achieve deleting the unwanted files from the server only, pause the laptop folder for safety, set the desktop folder to send only and the server to receive only. This worked like a charm. (Though the file scanning was slow as usual for my 10s of thousands of files and thousands of directories.)
In general, just pause the syncing on any devices that you do not want to be involved. So set all the devices that should delete files to recieve only, one of the remaining devices to send only, and all others to paused.
Also, to get more insight on what ignore rules had the most impact, I edited the .stignore file on the server a few times during step 5 and waited for the results. This allowed me to compare the effect of each rule, and made it easier to double-check that my ignore files worked correctly.
Thanks for the guide!
