Hi there. I’ve got a problem when Syncthing can’t sync file/folder from one peer which do non exist anymore.
How can I clean download queue on my PC? To avoid that message.
Removing the device from the config should suffice, if it does not exist any more.
Thank you so much, it helped.
And there is a similar question. I have 4 devices and in this case we can say that 1 of them is source and 3 of them are receivers. All devices can see each other. So we have this:
When that file calendar_backup_2025-05-04_20-46-41.tar.gz.gpg was on Source’s disk, it was not empty. Like 2-3Mbytes but error was the same. I tried to delete this file from the source1 and rescan my folder but it didn’t help. How can I fix that issue?
Thanks in advance.
Anyone?
Brute force options:
Hope that helps!
When this file was on Source1 the error was the same. I deleted it but error persist. For now it do not exist on any of my systems.
I’ll try and get back in this topic.
I’ve created file on Source. It tells that everything is up to date.
Try creating a dummy file in the expected location on Receivers 2 or 3 - see if that propagates correctly and, if so, then delete it.
