I have a huge list of files that have the error ‘file modified but not rescanned’ …
Even when I don’t see a case mismatch in the file name, the advice is that I should rename the folder and allow it to synchronize from scratch again.
Won’t this force having both folders (original and renamed) all the sync systems? Or even delete the original folder from my machine because it doesn’t exist any more in the system I renamed it?
At least the renamed folder was propagated to the other nodes
I did a backup and now I’m waiting to see what happens with the original… (6GB over the internet…)
