I’ve setup a discovery and relay server in my LAN because i have more than one subnet.
I have one client on each. They both connect to the central gateway which is running both discovery and relay server.
i’ve setup both clients to listen on:
tcp://0.0.0.0:22000,quic://0.0.0.0:22000,relay://10.0.0.1/?id=MYLONGID
Both clients show on logs “joining relay…” and on the GUI they do show 3 listeners always:
relay://10.0.0.1....
tcp://0.0.0.0:22000
they also both show always 2 discoveries:
IPv4 local
global@https://10.0.0.1.....
At this point, clicking add new devices doesn’t show the IDs as if they were on local discovery. And adding the IDs manually just keep them always “disconnected” even though they are all hooked up to the same discovery and same relay.
Already triple checked IDs and logs. On the logs, there’s nothing ever from discovery… either on client logs or the stdicosrv daemon!
