Help with syncing on Unraid
I am trying to get Syncthing working on two Unraid servers to backup data. Totally new to this so really looking for help with setup. I have the two servers connected but when I try and add a shared folder I get Folder Path Missing. I don’t understand what I need to add to connect the two folders, should I be adding the folder path in the Edit Folder General tab ? Should I add something in the advanced section to setup the folder? Is there a log I can upload for help with this because I have no idea how to proceed.
Every Syncthing Folder has to have a path to the directory that you’re trying to sync. I don’t know anything about Unraid, but I’m guessing that when you added the shared folder that either the Folder Path was incorrect or blank. Definitely be adding the path to the directory in question.
