I am trying to install Sync on a server at my office that renders reports every 4 hours and pushes them to a folder. The idea is that I can sync the folder to my phone and laptop so when I am not in the office I can read them. My server is Windows server 2012 and my laptop is Win 7 and Ubuntu. Have not tried on the phone yet but I cannot see the server from wither laptop. I checked the logs and this is what I see after a restart:
[EDIW7] 12:44:44 INFO: Detected 0 NAT services
[EDIW7] 12:44:54 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
[EDIW7] 12:44:54 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
[EDIW7] 12:44:54 INFO: c.S.listenerSupervisor: Failed service 'dynamic+https://relays.syncthing.net/endpoint' (1.000000 failures of 2.000000), restarting: true, error: "{dynamic+https://relays.syncthing.net/endpoint dynamic+https://relays.syncthing.net/endpoint} returned unexpectedly", stacktrace: [unknown stack trace]
[EDIW7] 12:44:59 INFO: Couldn't fetch release information: Get https://upgrades.syncthing.net/meta.json: dial tcp 82.196.13.137:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
[EDIW7] 12:44:59 INFO: Automatic upgrade: no version to select
[EDIW7] 12:45:02 INFO: Couldn't fetch release information: Get https://upgrades.syncthing.net/meta.json: dial tcp 82.196.13.137:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
[EDIW7] 12:45:15 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
[EDIW7] 12:45:15 INFO: c.S.listenerSupervisor: Failed service 'dynamic+https://relays.syncthing.net/endpoint' (1.615513 failures of 2.000000), restarting: true, error: "{dynamic+https://relays.syncthing.net/endpoint dynamic+https://relays.syncthing.net/endpoint} returned unexpectedly", stacktrace: [unknown stack trace]
[EDIW7] 12:45:15 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
[EDIW7] 12:45:36 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
[EDIW7] 12:45:36 INFO: c.S.listenerSupervisor: Failed service 'dynamic+https://relays.syncthing.net/endpoint' (1.994575 failures of 2.000000), restarting: true, error: "{dynamic+https://relays.syncthing.net/endpoint dynamic+https://relays.syncthing.net/endpoint} returned unexpectedly", stacktrace: [unknown stack trace]
[EDIW7] 12:45:36 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
[EDIW7] 12:45:57 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
[EDIW7] 12:45:57 INFO: Entering the backoff state.
[EDIW7] 12:45:57 INFO: c.S.listenerSupervisor: Failed service 'dynamic+https://relays.syncthing.net/endpoint' (2.227601 failures of 2.000000), restarting: false, error: "{dynamic+https://relays.syncthing.net/endpoint dynamic+https://relays.syncthing.net/endpoint} returned unexpectedly", stacktrace: [unknown stack trace]
Not really sure how to proceed here?
EDIT: I have tried turning off the firewall and the AV on both sides to make sure it isn’t blocking anything.
EDIT2: And the laptops (Win 7 and Linux) can see each other.
