Hi. I’m hoping there is a solution for my seemingly read only sync to Android. I’ve done a bit of searching and reading but haven’t found anything I can connect with exactly what I’m experiencing.
I have syncthing instead on a Debian server using this guide How to Install Syncthing on Debian desktop/server
It’s appears to be all working correctly and syncs two way to my Linux Mint desktop.
When it come to my phone, Pixel 4a Android 13, though the files sync through and I have a folder which says send and receive and that Android has given it read write access however if I open a document to edit each app I’ve tried says read only.
The Android log shows some permissions errors. But I’m not sure how to interpret them.
Any advice pointers or hints appreciated.
Thanks
-24 07:38:19.850 W/libsyncthing.so( 6486): type=1400 audit(0.0:690): avc: denied { bind } for scontext=u:r:untrusted_app:s0:c239,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c239,c256,c512,c768 tclass=netlink_route_socket permissive=0 bug=b/155595000 app=com.nutomic.syncthingandroid 11-24 07:38:19.850 W/libsyncthing.so( 6486): type=1400 audit(0.0:691): avc: denied { bind } for scontext=u:r:untrusted_app:s0:c239,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c239,c256,c512,c768 tclass=netlink_route_socket permissive=0 bug=b/155595000 app=com.nutomic.syncthingandroid 11-24 07:38:21.182 W/Parcel ( 6412): Expecting binder but got null! 11-24 07:38:21.189 E/OpenGLRenderer( 6412): Unable to match the desired swap behavior. 11-24 07:38:21.243 W/libsyncthing.so( 6486): type=1400 audit(0.0:692): avc: denied { bind } for scontext=u:r:untrusted_app:s0:c239,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c239,c256,c512,c768 tclass=netlink_route_socket permissive=0 bug=b/155595000 app=com.nutomic.syncthingandroid 11-24 07:38:21.243 W/libsyncthing.so( 6486): type=1400 audit(0.0:693): avc: denied { bind } for scontext=u:r:untrusted_app:s0:c239,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c239,c256,c512,c768 tclass=netlink_route_socket permissive=0 bug=b/155595000 app=com.nutomic.syncthingandroid 11-24 07:38:22.871 W/Parcel ( 6412): Expecting binder but got null! 11-24 07:38:22.890 E/OpenGLRenderer( 6412): Unable to match the desired swap behavior. 11-24 07:38:24.846 W/Parcel ( 6412): Expecting binder but got null! 11-24 07:38:24.854 E/OpenGLRenderer( 6412): Unable to match the desired swap behavior. 11-24 07:38:25.547 W/Parcel ( 6412): Expecting binder but got null! 11-24 07:38:25.565 E/OpenGLRenderer( 6412): Unable to match the desired swap behavior.
