I think these apply to whatever might have been selected by the user in the restore dialog, so potentially anything from a directory to multiple files or whatever.
Thank you André, that’s what I searched in github to not disturb but didn’t found when using one of the strings… Unfortunately my skills in coding doesn’t seem to help me as I can’t see in the code what triggers/were is used this strings: {…} statement. Don’t worry… I’ll learn, un jour ou l’autre.
Yes, these ones are not quite easy to spot, because they are just given as configuration values to a third-party library (the fancytree package). Glad I could help.
