Hello , I need help, I am exclude all files except .jpg extensions .mp4 . I try :
! .jpg ! .mp4 *
But it does not work
How please ? Thank you.
! .jpg ! .mp4 *
This should work:
!*.mp4
Hello , I try this but the subdirectory does its not taken into account, such as:
titi.jpg not syncro .
thank you
Your post is quite unclear in what you mean. I’ve added triple-ticks
```around your snippet, but you should probably not have spaces around the backslashes, and you may want to exclude something using the
operator.
inside the sub folder foo\tata\
ignore pattern.
@jresine: the lines inside the .stignore
file should not have any spaces (like in your first post). Are you sure, your files contains exactly the 3 lines of my previous post?
in some of my ignore files and it ignores all jpg files, even in sub folders. Could it be, that the !
notation handles this differently?
You probably need to unignore directories preceeding the file too.
So the complete .stignore
file should be:
!**/*.jpg
!*.mp4
!**/*.mp4
right?
Hello and thank you for your response .
wweich your script does not work either.
subdirectory are not ignored
You probably need
!/tutu.jpg
!/foo/
!/foo/tata/
!/foo/tata/titi.jpg
