After creating the syncthing@.service file in /lib/systemd/system, I created a user on my system called syncthing.
Then I run:
systemctl enable syncthing@syncthing.service
And then:
systemctl start syncthing@syncthing.service
Then I edit the config.xml file in the syncthing home folder to adjust the listening IP address to the machine’s IP.
Then, I open up a browser and load Syncthing. After that, I add the remote machine to Syncthing on my laptop and wait for the prompt on the server.
Now that we’re connected, I want to sync a folder on my laptop to the server. Creating that share prompts the server and when I attempt to point the share on the server to the intended sync folder, every time I get permissions denied to create .stignore and a folder as well.
So, I find myself manually creating that folder…
I thought I could simply setfacl -m user:syncthing:rw that folder on the server to give syncthing user rights…but I’m probably missing a step or doing something wrong.
User created system wide services go into /etc/systemd/system. /lib (resp. /usr/lib) is for service shipped as part of a program (e.g. if you install debian packages, that’s where a service will be).
What operating system runs on the server?
I don’t know setfacl, so the following might not apply: On your command I don’t recognize a recursive option (if there is any existing content). And the execute permission isn’t there, which is required to “enter”/traverse a directory.
