I seem to be locked into the Dark theme - no matter how much I try to set the theme to light/default/whatever or C-r or C-f5, it doesn’t change.
This started when I changed the firefox theme to Dark. I like Dark in the evening and Light or default in the daytime.
It was cool that the Syncthing GUI changed to Dark automatically when I changed the firefox theme to Dark - but uncool that it doesn’t change back to Light!!
I think it’s usually Ctrl+Shift+F5.
You need to save the theme before you refresh.
Does the theme setting get saved in the ui, so stays set to light after refresh?
I tried chrome - syncthing starts off as light (default). If I set the syncthing theme to dark - nothing happens!
OK - think I see what my problem is. I tried futzing with the gtk-3 theme using lxappearance and both firefox and chrome follow the gtk-3 theme (light or dark). So that’s nice and understandable and probably proper behaviour.
Thanks for the hints and kicks in the right direction!
EDIT: I just tried it again (lxappearance) and neither chrome nor firefox are following my changes even on C-f5. Sigh! Back to square one.
