when im updating syncthing im getting this error. i read this post http://ubuntuforums.org/showthread.php?t=2196704 of how to add key. but i cant find any syncthing key hash. someone face this before?
Please refer to these instructions: https://apt.syncthing.net/
I still have the same error. There is any other way to save the key?
How did you install Syncthing?
Did you install it with Ubuntu (for example, with apt-get), or did you download it from syncthing.net?
Please post the exact commands you ran, and the exact output you say.
some how i managed to install it from this guide.
here is the prompts. when i sudo apt-get update.
Hit http://ports.ubuntu.com trusty/multiverse Translation-en
Hit http://ports.ubuntu.com trusty/restricted Translation-en
Hit http://ports.ubuntu.com trusty/universe Translation-en
Ign http://ports.ubuntu.com trusty/main Translation-en_US
Ign http://ports.ubuntu.com trusty/multiverse Translation-en_US
Ign http://ports.ubuntu.com trusty/restricted Translation-en_US
Ign http://ports.ubuntu.com trusty/universe Translation-en_US
Fetched 2,917 kB in 24s (119 kB/s)
Reading package lists... Done
W: GPG error: http://apt.syncthing.net syncthing InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2B9FAE4C37C86D31
orangepi@OrangePI:~$
when i trying to add the key as the guide says.
orangepi@OrangePI:~$ curl -s https://syncthing.net/release-key.txt | sudo apt-key add -
gpg: no valid OpenPGP data found.
thanks.
What is the output of curl -s https://syncthing.net/release-key.txt on its own?
i think i managed to solve it. i tried the following
gpg --keyserver subkeys.pgp.net --recv-keys 2B9FAE4C37C86D31 (this is what the error message show)
gpg --export --armor 2B9FAE4C37C86D31|sudo apt-key add -
then when im doing update syncthing version change only when im doing reinstall like sudo apt-get install syncthing
is it should be like that?.
Can you answer canton7’s question about the output of the curl command? That should work, and something isn’t right if it doesn’t work.
I think your curl is broken somehow…
Indeed, that command should print a PGP public key to stdout.
