GPG error when setting up syncthing in Debian 12
New to syncthing and followed the documentation to setup for Debian but when I run apt-get update to pull the repository I get a GPG error saying the signature couldn’t be verified. Wondering if anyone knows whats up? I attached the error output to the thread thanks to anyone who gives this a look.
It looks like the public key wasn’t installed.
Maybe caused by this?
Note the necessary -L option to curl so it correctly downloads the key file.
I tried adding the -L flag to the end of the command and I still get the same error output. Is there anything I need to do to refresh to make this work?
Instead of cURL, try wget:
wget -O /usr/share/keyrings/syncthing-archive-keyring.gpg https://syncthing.net/release-key.gpg
Or, paste https://syncthing.net/release-key.gpg into a web browser to download the GnuPG key. Then move the file to /usr/share/keyrings/syncthing-archive-keyring.gpg on your Debian machine.
Worked! Thanks so much for your help. Any ideas what was going on with cURL?
None, as you didn’t show any output from that. :wink:
Our instructions currently reference /etc/apt/keyrings/ instead of /usr/share/keyrings/. Maybe you mixed something up there and the APT sources file was pointing at the wrong location?
I just tried the instructions on https://apt.syncthing.net/ again and they worked fine.
