I’ve been going around the docs and this forum looking for an answer but couldn’t find it, so I apologize if my question has already been answered before.
I have 3 machines (A, B and C).
A and B are on the same local network and C is on a remote location.
Let’s assume there’s only one (same) share on each machine, what would be the better way of connecting them:
C <-> A <-> B
C <-> A | C <-> B
C <-> A | C <-> B | A <-> B
For 2 and 3, I’m concerned that C will have to use twice as bandwidth as 1 for sending.
Also, are 2 and 3 actually different in a real-world scenario?
Syncthing naturally fetches more data from the faster peer, which in your case should be the local network. Yes, initially all bandwidth will come from C as C is the only one with the file, but over time it should shift more towards each other in the local network as they have more and more data.
