Hi All, Thanks for reading this.
I have been using Syncthing on my Pixel2 for a while now without issue. I have it set to run only when connected to AC power, and when connected to my home wifi network. Every night when my phone is plugged in syncthing runs and its basically invisible to me - the way I want it to be.
Now I’ve setup my wife’s phone, a Samsung galaxy S10 with the same settings as my phone. But for some reason it does not run when I plug the phone in. If I open the syncthing app manually and the run conditions are met, then the phone syncs and everything is happy. The problem is of course I don’t want any user intervention.
Are there some OS settings somewhere that I can check into? Something others know to be required for this to work?
