Hi
I have 3 devices one being a desktop and the rest are android cyanogen mod on 4.4.4 (arm7).
I started sync between these devices, all seem to be able see eachother. I also got an initial sync done (mobile to desktop). I then added bunch of more files and folders on mobile. Then I added the second mobile (2nd sees the desktop directly). Now my sync has been stuck on mobiles for 2 days, not much moving is happening. The desktop seems to have the initial file number alright (but is still trying to sync a single file over 6 hours. it is a text file). But the mobile devices are kind of out of whack, nothing seems to move between all these 3. Especially the last one I added has not caught up in 2 days, still missing over 700 files out of 1900. The sync totals around 3 gb which is not heavy whatsoever.
What do I do to resolve this ? I restart all the devices and services with no light in the end. It seems to be that this is more of a mobile issue. I do not see any issue reporting in the logs on mobiles.
I am using 0.9.5 on dekstop, 0.8.5 on mobiles
thanks
