Folder Structure not function
I have installed Syncthing on my local server via Docker. For example, I can link my smartphone and the Syncthing server with each other.
What do I need to consider when creating folders? I want to send files from my smartphone to a folder on the server. That doesn’t work for me.
If I set up the Dream folder on my smartphone with the file path and set up the folder with the path there, the synchronization works. But I can’t see the file in the folder on the server, for example.
Where can I find detailed information on this?
