One of my Windows syncthing-installations has mounted a network share (“Z:…”). The machine that hosts this share reboots every night a 4am. After this time the folder won’t come back and syncthing says “folder path missing”.
Restarting syncthing in the GUI does not help. I need to shut it down and then start it manually. Then the folder is working fine again.
Rescanning should fix the issue. If you are using intofy or something along the lines that defers a scan, you might have to force a scan yourself from the UI.
I don’t know what “intofy” is, but rescanning the folder doesn’t help… The path is online - when I copy it from syncthing and paste it into the Windows explorer it opens right away.
Edit: Ok, that’s funny. The problem only occurs when syncthing is installed unter C:\Program files\syncthing. When I run it from C:\syncthing everything works fine. Any ideas?
