Folder not syncing
Yes.
Since I used the package manager Homebrew to install syncthing I am not really sure how syncthing is being started. I can just kill the process ID but is there a better way?
I’m not really sure what homebrew does. Try launchctl unload ~/Library/LaunchAgents/*syncthing*. If that doesn’t complain, it probably worked.
Also I am seeing the following in the log:
INFO: syncthing v0.11.25 "Aluminium Ant" (go1.5.1 darwin-amd64 default) brew@yosemitevm.local 2015-09-13 09:46:17 UTC
INFO: Database block cache capacity 65536 KiB
FATAL: Cannot open database: resource temporarily unavailable - Is another copy of Syncthing already running?
Yeah there seems to be a bigger problem: STTRACE=upnp syncthing gives:
[RMVXH] 2015/09/17 09:42:49.096312 main.go:772: INFO: Database block cache capacity 65536 KiB
[RMVXH] 2015/09/17 09:42:49.096391 main.go:605: FATAL: Cannot open database: resource temporarily unavailable - Is another copy of Syncthing already running?
[monitor] 2015/09/17 09:42:49.097583 monitor.go:158: INFO: Syncthing exited: exit status 1
[monitor] 2015/09/17 09:42:50.098294 monitor.go:75: WARNING: 4 restarts in 4.076156539s; not retrying further
Well, if you read the logs, it complains that another copy is running.
I think the other copy is stopped now.
[monitor] 2015/09/17 09:49:15.192100 monitor.go:94: INFO: Starting syncthing
[RMVXH] 2015/09/17 09:49:15.206816 main.go:475: INFO: syncthing v0.11.25 "Aluminium Ant" (go1.5.1 darwin-amd64 default) brew@yosemitevm.local 2015-09-13 09:46:17 UTC
[RMVXH] 2015/09/17 09:49:15.206937 main.go:476: INFO: My ID: RMVXHID-O2GRZGN-VZVOLIW-WIXFUPV-CNOQ3GT-VPA2AZO-GY66AM6-7RXX2AN
[RMVXH] 2015/09/17 09:49:15.215695 main.go:772: INFO: Database block cache capacity 65536 KiB
[RMVXH] 2015/09/17 09:49:17.627482 model.go:194: OK: Ready to synchronize default (read-write)
[RMVXH] 2015/09/17 09:50:02.170114 model.go:194: OK: Ready to synchronize projects (read-write)
[RMVXH] 2015/09/17 09:50:02.170171 main.go:827: INFO: Starting web GUI on http://127.0.0.1:8384/
[RMVXH] 2015/09/17 09:50:02.173104 main.go:904: INFO: Starting local discovery announcements
[RMVXH] 2015/09/17 09:50:02.174056 main.go:909: INFO: Starting global discovery announcements
[RMVXH] 2015/09/17 09:50:02.174509 main.go:689: INFO: Device FJOOVCS-6MSG6E7-DN6ZVBQ-YDXYHWM-VGS4KGP-IVB2FWO-OT7CZWD-SY67CQS is "tokyo.local" at [dynamic]
[RMVXH] 2015/09/17 09:50:02.174571 main.go:689: INFO: Device RMVXHID-O2GRZGN-VZVOLIW-WIXFUPV-CNOQ3GT-VPA2AZO-GY66AM6-7RXX2AN is "wilbur.local" at [dynamic]
[RMVXH] 2015/09/17 09:50:02.175058 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en2
[RMVXH] 2015/09/17 09:50:02.175359 upnp.go:177: DEBUG: listen udp4 0.0.0.0:61224->239.255.255.250: setsockopt: no such network interface
[RMVXH] 2015/09/17 09:50:02.175383 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on lo0
[RMVXH] 2015/09/17 09:50:02.175463 upnp.go:190: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on lo0
[RMVXH] 2015/09/17 09:50:02.175498 upnp.go:200: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on lo0
[RMVXH] 2015/09/17 09:50:02.175552 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on lo0
[RMVXH] 2015/09/17 09:50:02.175620 upnp.go:190: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on lo0
[RMVXH] 2015/09/17 09:50:02.175647 upnp.go:200: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on lo0
[RMVXH] 2015/09/17 09:50:02.175663 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en2
[RMVXH] 2015/09/17 09:50:02.175701 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on bridge0
[RMVXH] 2015/09/17 09:50:02.175730 upnp.go:177: DEBUG: listen udp4 0.0.0.0:51464->239.255.255.250: setsockopt: no such network interface
[RMVXH] 2015/09/17 09:50:02.175748 upnp.go:177: DEBUG: listen udp4 0.0.0.0:51217->239.255.255.250: setsockopt: no such network interface
[RMVXH] 2015/09/17 09:50:02.175759 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en3
[RMVXH] 2015/09/17 09:50:02.175769 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en0
[RMVXH] 2015/09/17 09:50:02.175816 upnp.go:177: DEBUG: listen udp4 0.0.0.0:56475->239.255.255.250: setsockopt: no such network interface
[RMVXH] 2015/09/17 09:50:02.175835 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en0
[RMVXH] 2015/09/17 09:50:02.175863 upnp.go:190: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en3
[RMVXH] 2015/09/17 09:50:02.175877 upnp.go:177: DEBUG: listen udp4 0.0.0.0:54752->239.255.255.250: setsockopt: no such network interface
[RMVXH] 2015/09/17 09:50:02.175900 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en1
[RMVXH] 2015/09/17 09:50:02.175939 upnp.go:177: DEBUG: listen udp4 0.0.0.0:52280->239.255.255.250: setsockopt: no such network interface
[RMVXH] 2015/09/17 09:50:02.175949 upnp.go:200: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en3
[RMVXH] 2015/09/17 09:50:02.175958 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en1
[RMVXH] 2015/09/17 09:50:02.176001 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en3
[RMVXH] 2015/09/17 09:50:02.176017 upnp.go:177: DEBUG: listen udp4 0.0.0.0:52758->239.255.255.250: setsockopt: no such network interface
[RMVXH] 2015/09/17 09:50:02.176026 rwfolder.go:337: INFO: Completed initial scan (rw) of folder default
[RMVXH] 2015/09/17 09:50:02.176092 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on utun0
[RMVXH] 2015/09/17 09:50:02.176110 upnp.go:190: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en3
[RMVXH] 2015/09/17 09:50:02.176146 upnp.go:177: DEBUG: listen udp4 0.0.0.0:50530->239.255.255.250: setsockopt: no such network interface
[RMVXH] 2015/09/17 09:50:02.176152 upnp.go:200: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en3
[RMVXH] 2015/09/17 09:50:02.176163 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on bridge0
[RMVXH] 2015/09/17 09:50:02.176212 upnp.go:177: DEBUG: listen udp4 0.0.0.0:62143->239.255.255.250: setsockopt: no such network interface
[RMVXH] 2015/09/17 09:50:02.176231 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on utun0
[RMVXH] 2015/09/17 09:50:02.176280 upnp.go:177: DEBUG: listen udp4 0.0.0.0:64653->239.255.255.250: setsockopt: no such network interface
[RMVXH] 2015/09/17 09:50:02.189439 gui.go:221: INFO: API listening on 127.0.0.1:8384
[RMVXH] 2015/09/17 09:50:12.175616 upnp.go:221: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on lo0 finished.
[RMVXH] 2015/09/17 09:50:12.175655 upnp.go:221: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on lo0 finished.
[RMVXH] 2015/09/17 09:50:12.175912 upnp.go:221: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en3 finished.
[RMVXH] 2015/09/17 09:50:12.176136 upnp.go:221: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en3 finished.
[RMVXH] 2015/09/17 09:50:12.176168 upnpsvc.go:46: INFO: No UPnP device detected
It could be the network I am on does not allow upnp. Is upnp required for devices to connect outside of my LAN?
There is no UPnP in this network. Was the previous error you posted (about port 0) in a different location?
Yes it was on my home LAN. I am currently on another network.
Is UPnP required to connect a to device from outside my LAN?
Well this LAN does not have UPnP, so you’d have to setup manual port forwarding (or UPnP or portforward on the other peer), or get UPnP enabled.
UPnP exposes a service on to the internet, via the router. For syncthing to connect, either end of the connection has to be exposed to the internet.
The network I am currently on is out of my control but I can set up port forwarding on my home network. It seems that is the way to go. Correct? What port do I need to forward to my home device?
See the firewall page on the docs site, basically it’s port 22000. But rerun the upnp debug thing when you’re on the network where it’s relevant, please.
Will do. Thank you for your help!
after running STTRACE=upnp syncthing
[monitor] 2015/09/17 23:32:04.069217 monitor.go:94: INFO: Starting syncthing
[FJOOV] 2015/09/17 23:32:04.078026 main.go:475: INFO: syncthing v0.11.25 "Aluminium Ant" (go1.5.1 darwin-amd64 default) brew@yosemitevm.local 2015-09-13 09:46:17 UTC
[FJOOV] 2015/09/17 23:32:04.078149 main.go:476: INFO: My ID: FJOOVCS-6MSG6E7-DN6ZVBQ-YDXYHWM-VGS4KGP-IVB2FWO-OT7CZWD-SY67CQS
[FJOOV] 2015/09/17 23:32:04.081558 main.go:772: INFO: Database block cache capacity 65536 KiB
[FJOOV] 2015/09/17 23:32:06.681393 model.go:194: OK: Ready to synchronize default (read-write)
[FJOOV] 2015/09/17 23:33:00.747674 model.go:194: OK: Ready to synchronize projects (read-write)
[FJOOV] 2015/09/17 23:33:00.747742 main.go:827: INFO: Starting web GUI on http://127.0.0.1:8384/
[FJOOV] 2015/09/17 23:33:00.751501 main.go:904: INFO: Starting local discovery announcements
[FJOOV] 2015/09/17 23:33:00.752900 main.go:909: INFO: Starting global discovery announcements
[FJOOV] 2015/09/17 23:33:00.756332 main.go:689: INFO: Device FJOOVCS-6MSG6E7-DN6ZVBQ-YDXYHWM-VGS4KGP-IVB2FWO-OT7CZWD-SY67CQS is "tokyo.local" at [dynamic]
[FJOOV] 2015/09/17 23:33:00.756734 main.go:689: INFO: Device RMVXHID-O2GRZGN-VZVOLIW-WIXFUPV-CNOQ3GT-VPA2AZO-GY66AM6-7RXX2AN is "wilbur.local" at [dynamic]
[FJOOV] 2015/09/17 23:33:00.756813 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en6
[FJOOV] 2015/09/17 23:33:00.756840 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en2
[FJOOV] 2015/09/17 23:33:00.756864 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en2
[FJOOV] 2015/09/17 23:33:00.756911 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on lo0
[FJOOV] 2015/09/17 23:33:00.757048 upnp.go:177: DEBUG: listen udp4 0.0.0.0:61007->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.757068 upnp.go:177: DEBUG: listen udp4 0.0.0.0:58099->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.757078 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on lo0
[FJOOV] 2015/09/17 23:33:00.757092 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en10
[FJOOV] 2015/09/17 23:33:00.757117 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on fw0
[FJOOV] 2015/09/17 23:33:00.757168 upnp.go:177: DEBUG: listen udp4 0.0.0.0:64380->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.757184 upnp.go:177: DEBUG: listen udp4 0.0.0.0:56346->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.757197 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en1
[FJOOV] 2015/09/17 23:33:00.757203 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en7
[FJOOV] 2015/09/17 23:33:00.757222 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on bridge0
[FJOOV] 2015/09/17 23:33:00.757242 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on fw0
[FJOOV] 2015/09/17 23:33:00.757278 upnp.go:177: DEBUG: listen udp4 0.0.0.0:62351->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.757290 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en5
[FJOOV] 2015/09/17 23:33:00.757325 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on bridge0
[FJOOV] 2015/09/17 23:33:00.757340 upnp.go:190: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en1
[FJOOV] 2015/09/17 23:33:00.757350 upnp.go:190: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on lo0
[FJOOV] 2015/09/17 23:33:00.757363 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en7
[FJOOV] 2015/09/17 23:33:00.757374 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en0
[FJOOV] 2015/09/17 23:33:00.757388 upnp.go:177: DEBUG: listen udp4 0.0.0.0:53852->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.757398 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en3
[FJOOV] 2015/09/17 23:33:00.757421 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en4
[FJOOV] 2015/09/17 23:33:00.757439 upnp.go:177: DEBUG: listen udp4 0.0.0.0:61189->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.757453 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on utun0
[FJOOV] 2015/09/17 23:33:00.757477 upnp.go:177: DEBUG: listen udp4 0.0.0.0:53054->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.757490 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en10
[FJOOV] 2015/09/17 23:33:00.757530 upnp.go:177: DEBUG: listen udp4 0.0.0.0:61377->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.757542 upnp.go:177: DEBUG: listen udp4 0.0.0.0:62709->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.757548 upnp.go:177: DEBUG: listen udp4 0.0.0.0:61578->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.757553 upnp.go:190: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on lo0
[FJOOV] 2015/09/17 23:33:00.757583 upnp.go:200: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on lo0
[FJOOV] 2015/09/17 23:33:00.757627 upnp.go:177: DEBUG: listen udp4 0.0.0.0:62436->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.757679 upnp.go:200: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on lo0
[FJOOV] 2015/09/17 23:33:00.757719 upnp.go:177: DEBUG: listen udp4 0.0.0.0:57036->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.757730 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en1
[FJOOV] 2015/09/17 23:33:00.757783 rwfolder.go:337: INFO: Completed initial scan (rw) of folder default
[FJOOV] 2015/09/17 23:33:00.757803 upnp.go:190: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en1
[FJOOV] 2015/09/17 23:33:00.757835 upnp.go:200: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en1
[FJOOV] 2015/09/17 23:33:00.757890 upnp.go:200: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en1
[FJOOV] 2015/09/17 23:33:00.757922 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en3
[FJOOV] 2015/09/17 23:33:00.757975 upnp.go:177: DEBUG: listen udp4 0.0.0.0:55521->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.757984 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en0
[FJOOV] 2015/09/17 23:33:00.758030 upnp.go:177: DEBUG: listen udp4 0.0.0.0:60393->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.758039 upnp.go:177: DEBUG: listen udp4 0.0.0.0:54872->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.758044 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en8
[FJOOV] 2015/09/17 23:33:00.758092 upnp.go:177: DEBUG: listen udp4 0.0.0.0:63872->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.758099 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en5
[FJOOV] 2015/09/17 23:33:00.758154 upnp.go:177: DEBUG: listen udp4 0.0.0.0:56739->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.758168 upnp.go:177: DEBUG: listen udp4 0.0.0.0:54870->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.758176 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en4
[FJOOV] 2015/09/17 23:33:00.758259 upnp.go:177: DEBUG: listen udp4 0.0.0.0:56432->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.758268 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en6
[FJOOV] 2015/09/17 23:33:00.758312 upnp.go:177: DEBUG: listen udp4 0.0.0.0:64174->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.758361 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on utun0
[FJOOV] 2015/09/17 23:33:00.758424 upnp.go:177: DEBUG: listen udp4 0.0.0.0:59726->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.758435 upnp.go:177: DEBUG: listen udp4 0.0.0.0:53589->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.758440 upnp.go:171: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en8
[FJOOV] 2015/09/17 23:33:00.758512 upnp.go:177: DEBUG: listen udp4 0.0.0.0:51408->239.255.255.250: setsockopt: no such network interface
[FJOOV] 2015/09/17 23:33:00.759002 upnp.go:227: DEBUG: Handling UPnP response:
HTTP/1.1 200 OK
ST: urn:schemas-upnp-org:device:InternetGatewayDevice:1
LOCATION: http://10.0.0.1:5000/Public_UPNP_gatedesc.xml
SERVER: Linux/2.6.12, UPnP/1.0, NETGEAR-UPNP/1.0
EXT:
CACHE-CONTROL: max-age=3600
USN: uuid:28a004f8-c8bc-9f4a-3d35-2d630e094b1a::urn:schemas-upnp-org:device:InternetGatewayDevice:1
[FJOOV] 2015/09/17 23:33:00.766343 gui.go:221: INFO: API listening on 127.0.0.1:8384
[FJOOV] 2015/09/17 23:33:01.063400 upnp.go:398: DEBUG: [http://10.0.0.1:5000/Public_UPNP_gatedesc.xml] Found urn:schemas-upnp-org:service:WANIPConnection:1 with URL http://10.0.0.1:5000/Public_UPNP_C3
[FJOOV] 2015/09/17 23:33:01.063419 upnp.go:398: DEBUG: [http://10.0.0.1:5000/Public_UPNP_gatedesc.xml] Found urn:schemas-upnp-org:service:WANPPPConnection:1 with URL http://10.0.0.1:5000/Public_UPNP_C5
[FJOOV] 2015/09/17 23:33:01.063930 upnp.go:144: DEBUG: UPnP discovery result 28a004f8-c8bc-9f4a-3d35-2d630e094b1a with services:
[FJOOV] 2015/09/17 23:33:01.063939 upnp.go:146: DEBUG: * [urn:upnp-org:serviceId:WANIPConn1] http://10.0.0.1:5000/Public_UPNP_C3
[FJOOV] 2015/09/17 23:33:01.063943 upnp.go:146: DEBUG: * [urn:upnp-org:serviceId:WANPPPConn1] http://10.0.0.1:5000/Public_UPNP_C5
[FJOOV] 2015/09/17 23:33:01.961721 connections.go:176: INFO: Established secure connection to RMVXHID-O2GRZGN-VZVOLIW-WIXFUPV-CNOQ3GT-VPA2AZO-GY66AM6-7RXX2AN at 10.0.0.121:50993-10.0.0.111:22000
[FJOOV] 2015/09/17 23:33:10.761575 upnp.go:221: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on lo0 finished.
[FJOOV] 2015/09/17 23:33:10.761630 upnp.go:221: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on lo0 finished.
[FJOOV] 2015/09/17 23:33:10.761673 upnp.go:221: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on en1 finished.
[FJOOV] 2015/09/17 23:33:10.761695 upnp.go:221: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on en1 finished.
[FJOOV] 2015/09/17 23:33:10.761783 upnp.go:460: DEBUG: SOAP Request URL: http://10.0.0.1:5000/Public_UPNP_C3
[FJOOV] 2015/09/17 23:33:10.761796 upnp.go:461: DEBUG: SOAP Action:
[FJOOV] 2015/09/17 23:33:10.761803 upnp.go:462: DEBUG: SOAP Request:
<?xml version="1.0" ?>
	<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
	<s:Body><u:AddPortMapping xmlns:u="urn:schemas-upnp-org:service:WANIPConnection:1">
	<NewRemoteHost></NewRemoteHost>
	<NewExternalPort>34880</NewExternalPort>
	<NewProtocol>TCP</NewProtocol>
	<NewInternalPort>22000</NewInternalPort>
	<NewInternalClient>10.0.0.121</NewInternalClient>
	<NewEnabled>1</NewEnabled>
	<NewPortMappingDescription>syncthing-34880</NewPortMappingDescription>
	<NewLeaseDuration>3600</NewLeaseDuration>
	</u:AddPortMapping></s:Body>
	</s:Envelope>
[FJOOV] 2015/09/17 23:33:10.764336 upnp.go:475: DEBUG: SOAP Response: 500
<s:Body>
<s:Fault>
<faultcode>s:Client</faultcode>
<faultstring>UPnPError</faultstring>
<detail>
<UPnPError xmlns="urn:schemas-upnp-org:control-1-0">
<errorCode>725</errorCode>
<errorDescription>OnlyPermanentLeasesSupported</errorDescription></UPnPError>
</detail>
</s:Fault>
</s:Body>
</s:Envelope>
[FJOOV] 2015/09/17 23:33:10.764435 upnp.go:460: DEBUG: SOAP Request URL: http://10.0.0.1:5000/Public_UPNP_C3
[FJOOV] 2015/09/17 23:33:10.764444 upnp.go:461: DEBUG: SOAP Action:
[FJOOV] 2015/09/17 23:33:10.764449 upnp.go:462: DEBUG: SOAP Request:
	<NewLeaseDuration>0</NewLeaseDuration>
	</s:Envelope>
[FJOOV] 2015/09/17 23:33:10.767396 upnp.go:475: DEBUG: SOAP Response: 500
<s:Body>
<s:Fault>
<detail>
<errorCode>402</errorCode>
<errorDescription>InvalidArgs</errorDescription></UPnPError>
</detail>
</s:Fault>
</s:Body>
</s:Envelope>
[FJOOV] 2015/09/17 23:33:10.767422 upnp.go:460: DEBUG: SOAP Request URL: http://10.0.0.1:5000/Public_UPNP_C3
[FJOOV] 2015/09/17 23:33:10.767428 upnp.go:461: DEBUG: SOAP Action:
[FJOOV] 2015/09/17 23:33:10.767432 upnp.go:462: DEBUG: SOAP Request:
	<NewExternalPort>15382</NewExternalPort>
	<NewPortMappingDescription>syncthing-15382</NewPortMappingDescription>
	</s:Envelope>
[FJOOV] 2015/09/17 23:33:10.770294 upnp.go:475: DEBUG: SOAP Response: 500
<s:Body>
<s:Fault>
<detail>
</detail>
</s:Fault>
</s:Body>
</s:Envelope>
[FJOOV] 2015/09/17 23:33:10.770369 upnp.go:460: DEBUG: SOAP Request URL: http://10.0.0.1:5000/Public_UPNP_C3
[FJOOV] 2015/09/17 23:33:10.770376 upnp.go:461: DEBUG: SOAP Action:
[FJOOV] 2015/09/17 23:33:10.770380 upnp.go:462: DEBUG: SOAP Request:
	</s:Envelope>
[FJOOV] 2015/09/17 23:33:10.773235 upnp.go:475: DEBUG: SOAP Response: 500
<s:Body>
<s:Fault>
<detail>
</detail>
</s:Fault>
</s:Body>
</s:Envelope>
[FJOOV] 2015/09/17 23:33:10.773259 upnp.go:460: DEBUG: SOAP Request URL: http://10.0.0.1:5000/Public_UPNP_C3
[FJOOV] 2015/09/17 23:33:10.773264 upnp.go:461: DEBUG: SOAP Action:
[FJOOV] 2015/09/17 23:33:10.773268 upnp.go:462: DEBUG: SOAP Request:
	<NewExternalPort>4368</NewExternalPort>
	<NewPortMappingDescription>syncthing-4368</NewPortMappingDescription>
	</s:Envelope>
[FJOOV] 2015/09/17 23:33:10.776397 upnp.go:475: DEBUG: SOAP Response: 500
<s:Body>
<s:Fault>
<detail>
</detail>
</s:Fault>
</s:Body>
</s:Envelope>
Ah. The router doesn’t support what we’re trying to set up. We should probably handle that some way.
As a workaround, if I remember correctly, try setting the upnp lease time to zero in the advanced config options.
