Just set up a Syncthing instance on a Raspberry Pi 4B with 270GB of files in 9 shared folders. Most seem to sync fine. But I’ve got two folders which are showing ‘Out of Sync’, and a yellow banner at the top with ‘Filesystem Watcher Errors’:
For the following folders an error occurred while starting to watch for changes. It will be retried every minute, so the errors might go away soon. If they persist, try to fix the underlying issue and ask for help if you can’t. Support
WhatsApp Media readdirent /media/ben/500GB/WhatsApp Media/WhatsApp Video: input/output error
Both these folders are shared with my phone (but others are too, and those ones are OK). They both have a bunch of failed items which also say ‘input/output error’. I can’t see anything more useful in the log, though I haven’t dug very far. Any thoughts? I couldn’t find anything relevant in the forum.
I restarted with the --reset-deltas switch. And I re-added the folder but with the ‘Ignore Permissions’ advanced setting. And now both folders seem to be syncing OK. The mismatching index thing might be a red herring.
