On Windows 11 in SyncTrayzor, I set up a Folder called code
with the path \\wsl$\Ubuntu\home\ploppz\code
(a location inside WSL). I get a “Filesystem Watcher Errors”:
For the following folders an error occurred while starting to watch for changes. It will be retried every minute, so the errors might go away soon. If they persist, try to fix the underlying issue and ask for help if you can’t.
code: Incorrect function.
It fails to set up this Folder and keeps retrying every minute to no avail.
