Filesystem Watcher Errors - Android
Hi, I use Syncthing to sync certain folders from my devices to my home server, a kind of backup. Unfortunately, the synchronization of the screenshot folder from my android phone doesn’t work and I get the following error message:
The full path should be /storage/emulated/0/Pictures/Screenshots
I also tried lstat manually via adb:
redfin:/ $  lstat /storage/emulated
/system/bin/sh: lstat: inaccessible or not found
But listing the screenshot-directory on the other hand works:
redfin:/ $ ls -la /storage/emulated/0/Pictures/Screenshots/
total 7655
The synchronization of the camera folder /storage/emulated/0/DCIM/Camera however is working perfectly fine.
I can’t explain this error and I also could not find anything helpful on the web. Any ideas?
I had some similar issues in the past. Could you try to change the whole path from
to
/sdcard/DCIM/Camera
and then try again? In order to change the path, you can remove and re-add the folder (or just use the Advanced Configuration if you know what you are doing).
That’s interesting, I didn’t know about this directory before. But my camera-folder is synchronizing fine. I’ve got only problems with the Screenshot directory.
Edit: I just realized that the error is still there (even with pointing the screenshot sync to /sdcard/DCIM/Camera) Probably it’s a problem with the Application. I’ll reinstall it and tell you the outcome!
Reinstalling the program didn’t help, the error message still occurs. But it’s also pretty weird that screenshots witch I take are now synced to the server but not the other way around though on both, server and phone the “Folder Type” is set to “Send & Receive”.
Edit: The phone is a Pixel 5 with an Android AOSP called GrapheneOS. It’s very security hardened and privacy focused which is why I first thought it might have something to do with it.
But why does this problem occure only with /storage/emulated/0/Pictures/Screenshots and not with all the other Syncs under /storage/emulated/
Edit 2:
I just noticed, that this means lstat isn’t existing on my phone in general. Is this a bug of the syncthing app?
I don’t think so. I also get the not found error when trying to call lstat like that, but the file watcher works fine regardless.
This may be some kind of a permission issue. The only thing that I can think about right now is that the /sdcard/Camera/DCIM folder seems to exist in Android by default from the very first boot, while the /sdcard/Pictures/Screenshots folder gets created only when you actually take the first screenshot.
Some screenshots of the Syncthing Web GUI from both sides would probably help. You should also check the log files, especially on Android, to see if there are any errors recorded there. See https://forum.syncthing.net/t/only-non-pdf-files-are-getting-deleted/16408/16 for how to get the logs on Android.
Thank you for the help tomasz86!
I get it working without errors by deleting the F-Droid Syncthing package and installing it from the Play Store. To be honest I don’t want to play around with it too much until I mess things up again ^^
For those who encounter the same problem:
My Camera pictures are syncing from /storage/emulated/0/DCIM/Camera
And my Screenshots syncing from /storage/emulated/0/Pictures/Screenshot/
Seems, that it was a problem with the F-Droid package …
Interesting. Are you using the official app or the Fork? As far as I know, there is no difference when it comes to the official one, regardless of the source.
I was using the official app Syncthing | F-Droid - Free and Open Source Android App Repository
I thought so too, which is why I was surprised. Well I’ll keep an eye on it in the future and see if it occurs again.
Did you recompile now with v1.13.1 to check it isn’t anything else that changed in between?
There’s no changes relating to the filesystem watcher in between v1.13.1 and v1.14.0.
Seems likely to be due to Android 11: In that discussion about the external SD being accessible, info was posted that suggest that now all “native filesystem calls” are routed through androids storage access framework. And that hardly implements inotify. If that’s, I guess the only option is to disable filesystem watching. As far as I recall the app had it’s own watching using android apis and then syncthing’s rest api before filesystem notifications were introduced in Syncthing itself - maybe that can be resurrected.
You can probably run with enough tracing to see exactly where the error originates and comment that out. My guess would be that it’s the part where we resolve the correct casing of the folder root.
Notify (underlying library) also does checks on all path components (resolving symlinks).
I don’t know what to do about android. On the one hand it is used by many (including me), on the other hand it is terrifying: It’s clear now that under certain circumstances android reports that paths are missing, when in fact it’s a permission issue. That will destroy user data (the thing they are so concerned about when it comes to privacy…). Probably one can handle it by having code in the wrapper, that checks that folder roots are accessible. I would hope it behaves sanely if that is the case. @Catfriend1 Do you already do something like that?
