I am using synchthing to copy 500Gb of files from my old computer to a new one. It seems to be copying fine, but there is the following annoying warning message.
I looked in config.xml and didn’t see any obvious typos.
There seems to be a leading slash in the folder path. I would double check what the path looks like in the config.
I looked and I don’t see a typo. Here is the config.xml: config.xml (13.2 KB)
Is the folder located on the local disk or is this some kind of network storage?
The folder is on the local disk. Good question, as network storage often has strange directory links.
I’d verify that the directory in question looks sensible on the local filesystem and on the remote devices (i.e., it’s not a file on linux with backslash in the name etc or something like that)
That seems sensible, I’ll do that. Thanks for the tip!
