Hi Guys, I have a 2-nodes setup I use to transfer files over my LAN. I don’t understand how file sync priorities work.
Scenario: 2 machines, “empty” Sync dir and empty sync queue on each.
- Go to machine 1, suspend sync w/ machine 2.
- Load Sync dir on machine 1 with 2 .m4v files and 2 .jpg files: A.jpg, A.m4v, B.jpg, B.m4v
- Rescan Sync folder on machine 1
- Check machine 2 has option “File Pull Order: Smallest First” activated on the Sync dir
- Resume sync w/ machine 2.
Result: machine 2 starts pulling A.jpg, then A.m4v, B.jpg, B.m4v
How can I get machine 2 to queue up files by increasing size order?
