When I run syncthing, I get this error:
fatal error: unexpected signal during runtime execution
[signal 0xc0000095 code=0x1003f addr=0x0 pc=0x468a64]
runtime stack:
time.now(0x9a, 0x45aee1, 0x7ffe0008)
/usr/local/go/src/runtime/sys_windows_386.s:429 +0x14
goroutine 1 [running, locked to thread]:
goroutine running on other thread; stack unavailable
goroutine 2 [runnable]:
runtime.forcegchelper()
/usr/local/go/src/runtime/proc.go:90
runtime.goexit()
/usr/local/go/src/runtime/asm_386.s:2287 +0x1
and I can’t even see any log comes out of it, what’s the problem…?
P.S.
Running this on a XP Home SP2 @2.40GHz 1GB Ram
calmh
(Jakob Borg)
September 23, 2015, 6:37am
#2
Can you post the full log? I.e. the panic log file that was created. At least the stuff leading up to the part you posted is interesting. Including the startup stuff about what version you are running etc.
I don’t see any log being generated.
Isn’t it locate at C:\Doc and setting\User\Application Data\Syncthing\ ?
calmh
(Jakob Borg)
September 24, 2015, 6:21am
#4
If no log, can you post the entire output you get, wherever it is you get it?
I get this when I run it from cmd, as I only type in syncthing without any parameter
and here is all the output(I think):
runtime stack:
runtime.gothrow(0x990ac8, 0x2a)
/usr/local/go/src/runtime/panic.go:503 +0x67 fp=0x7fd90 sp=0x7fd84
runtime.sigpanic()
/usr/local/go/src/runtime/os_windows.go:36 +0x53 fp=0x7fda0 sp=0x7fd90
time.now(0x194, 0x45aee1, 0x7ffe0008)
/usr/local/go/src/runtime/sys_windows_386.s:429 +0x14 fp=0x7fdac sp=0x7fda0
runtime.gc_unixnanotime(0x7fdc0)
/usr/local/go/src/runtime/mgc0.go:25 +0x21 fp=0x7fdbc sp=0x7fdac
runtime.unixnanotime(0x73816b3c, 0x9df2)
/usr/local/go/src/runtime/mgc0.c:2011 +0x28 fp=0x7fdcc sp=0x7fdbc
gc(0x7ff08)
/usr/local/go/src/runtime/mgc0.c:1463 +0x35d fp=0x7fef8 sp=0x7fdcc
runtime.gc_m()
/usr/local/go/src/runtime/mgc0.c:1371 +0xd2 fp=0x7ff18 sp=0x7fef8
runtime.onM(0xcee0f8)
/usr/local/go/src/runtime/asm_386.s:266 +0x50 fp=0x7ff1c sp=0x7ff18
runtime.mstart()
/usr/local/go/src/runtime/proc.c:818 fp=0x7ff20 sp=0x7ff1c
goroutine 1 [garbage collection, locked to thread]:
runtime.switchtoM()
/usr/local/go/src/runtime/asm_386.s:208 fp=0x1144be9c sp=0x1144be98
runtime.gogc(0x0)
/usr/local/go/src/runtime/malloc.go:469 +0x1aa fp=0x1144bebc sp=0x1144be9c
runtime.mallocgc(0x8, 0x873180, 0x0, 0x0)
/usr/local/go/src/runtime/malloc.go:341 +0x2c4 fp=0x1144bf14 sp=0x1144bebc
runtime.newobject(0x873180, 0x0)
/usr/local/go/src/runtime/malloc.go:353 +0x48 fp=0x1144bf28 sp=0x1144bf14
errors.New(0x9096c8, 0xb, 0x0, 0x0)
/usr/local/go/src/errors/errors.go:10 +0x38 fp=0x1144bf40 sp=0x1144bf28
io.init()
/usr/local/go/src/io/io.go:21 +0x56 fp=0x1144bf5c sp=0x1144bf40
hash.init()
/usr/local/go/src/hash/hash.go:43 +0x3f fp=0x1144bf60 sp=0x1144bf5c
crypto/sha256.init()
/usr/local/go/src/crypto/sha256/sha256block_decl.go:11 +0x3f fp=0x1144bf64 sp=0x1144bf60
main.init()
/go/src/github.com/syncthing/syncthing/cmd/syncthing/verbose.go:129 +0x45 fp=0x1144bfcc sp=0x1144bf64
runtime.main()
/usr/local/go/src/runtime/proc.go:58 +0xbd fp=0x1144bff0 sp=0x1144bfcc
runtime.goexit()
/usr/local/go/src/runtime/asm_386.s:2287 +0x1 fp=0x1144bff4 sp=0x1144bff0
/usr/local/go/src/runtime/proc.go:90 fp=0x11448ff0 sp=0x11448fec
runtime.goexit()
/usr/local/go/src/runtime/asm_386.s:2287 +0x1 fp=0x11448ff4 sp=0x11448ff0
created by runtime.init繚4
/usr/local/go/src/runtime/proc.go:87 +0x25
calmh
(Jakob Borg)
September 24, 2015, 9:21am
#6
So that’s before it even prints what version it is and so on? Then no idea, sorry. Corrupt download maybe?
That’s exactly what appear after I press enter, nothing else, not even a log, I downloaded a flash copy of zip from githhub and extract it on the computer and run it, the result is the same, not sure if it’s some sort of environment problem?
calmh
(Jakob Borg)
September 24, 2015, 9:28am
#8
Maybe. You haven’t told us anything about the environment, but I’m guessing some variant of windows based on you mentioning zip. Letting us know what you’re running might help. The
wweich
September 24, 2015, 9:39am
#9
@calmh :
@JinxGenius : Are you sure, you have the correct version? (syncthing-windows-386-v0.11.25.zip)
Did something change since 0.11.15, which could be causing problems on 32bit Windows?
That version was working fine:
Yes, I’m sure I downloaded the syncthing-windows-386-v0.11.25.zip, every other machine works fine, except this one, that’s why I kinda wonder what difference happened to this computer, but I couldn’t really tell by this output unless I have to read to whole GO compiler and the whole source code to debug it. Orz
You should try downloading go compiler, compiling hello world and seeing if it crashes. If not, try compiling syncthing, and see if that crashes.
system
(system)
closed
October 24, 2015, 10:45am
#13
