Hi, I’m trying to sync a folder called “PS1 Memcards" from Android/data/duckstation directory to a desktop PC, but as soon as I created the folder, it shows that it failed to send.
Another directory in the Android/data/ directory is working fine with another sync folder, so I don’t know why it’s not working in the Duckstation directory.
Well, that’s it. Syncthing does not have permission to read the file. I don’t know if you that is because it is already exclusively opened by some other process or some other problem. Does someone else have any specific suggestions?
