After installing with sudo snap install syncthing
and running it as syncthing
, I’ve got this message.
Looks like something is broken there. Now will syncthing
in snap
eat more resources than Ubuntu package version?
in snap
That’s likely a result of some kind of hardening by snap. It won’t use more resources, but it will get higher priority, i.e. is more likely to impact responsiveness of other applications if your system resources are maxed out.
Is it possible to set the priority using system config during snap
installation? syncthing
executable is a wrapper script there.
$ file `which syncthing`
/snap/bin/syncthing: symbolic link to /usr/bin/snap
You can set priority in systemd service files if you use that. E.g. I still have the following as I added that before the feature was added to Syncthing:
# /etc/systemd/system/syncthing@.service.d/override.conf
[Service]
Nice=10
I have no clue about snap itself.
I don’t think snap
package uses systemd
. I start it manually.
