Hi! I have syncthing on my main pc. I use it to also host a minecraft server (I use dynu ddns); I’m getting all the time this:
[VV3BK] 15:22:41 INFO: Failed to exchange Hello messages with OP3B6CY at 192.168.1.170:22000-XXX.XXX.XXX.XXX:YYYYY/tcp-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256: write tcp 192.168.1.170:22000->XXX.XXX.XXX.XXX:YYYYY: wsasend: An existing connection was forcibly closed by the remote host.
[VV3BK] 15:22:51 INFO: Failed to exchange Hello messages with XT3HB7I at [::]:22000-XXX.XXX.XXX.XXX:YYYYY/quic-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256: Application error 0x0: closing
[VV3BK] 15:23:16 INFO: Failed to exchange Hello messages with XT3HB7I at 192.168.1.170:22000-XXX.XXX.XXX.XXX:YYYYY/tcp-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256: write tcp 192.168.1.170:22000->XXX.XXX.XXX.XXX:YYYYY: wsasend: An existing connection was forcibly closed by the remote host.
[VV3BK] 15:23:16 INFO: Failed to exchange Hello messages with XT3HB7I at [::]:22000-XXX.XXX.XXX.XXX:YYYYY/quic-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256: Application error 0x0: closing
[VV3BK] 15:23:26 INFO: Failed to exchange Hello messages with XT3HB7I at 192.168.1.170:22000-XXX.XXX.XXX.XXX:YYYYY/tcp-server/TLS1.3-LS_CHACHA20_POLY1305_SHA256: write tcp 192.168.1.170:22000->XXX.XXX.XXX.XXX:YYYYY: wsasend: An existing connection was forcibly closed by the remote host.
[VV3BK] 15:23:31 INFO: Failed to exchange Hello messages with XT3HB7I at [::]:22000-XXX.XXX.XXX.XXX:YYYYY/quic-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256: Application error 0x0: closing
[VV3BK] 15:23:51 INFO: Failed to exchange Hello messages with XT3HB7I at [::]:22000-XXX.XXX.XXX.XXX:YYYYY/quic-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256: Application error 0x0: closing
[VV3BK] 15:23:51 INFO: Failed to exchange Hello messages with OP3B6CY at 92.168.1.170:22000-XXX.XXX.XXX.XXX:YYYYY/tcp-server/TLS1.3-LS_CHACHA20_POLY1305_SHA256: write tcp 192.168.1.170:22000->XXX.XXX.XXX.XXX:YYYYY: wsasend: An existing connection was forcibly closed by the remote host.
I also have a raspberry pi backup server (that also uses a ddns) but it doesn’t have any problem. I tried doing a fresh new install of windows 10 but nothing. I’m getting crazy! Turning of the firewall doesn’t help neither.
Without a ddns it works… can you help me?
