[MBF5Y] 2025/08/20 11:27:17 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
[MBF5Y] 2025/08/20 11:27:17 INFO: Lost primary connection to 7EP4AEC at 192.168.1.70:22000-192.168.1.80:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-62TFGJHI7E7G4Q99DJIHTUCJ2A: Syncthing is being stopped (0 remain)
[MBF5Y] 2025/08/20 11:27:17 INFO: Connection to 7EP4AEC at 192.168.1.70:22000-192.168.1.80:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-62TFGJHI7E7G4Q99DJIHTUCJ2A closed: Syncthing is being stopped
[MBF5Y] 2025/08/20 11:27:17 INFO: Lost primary connection to PDJKYGZ at [fe80::ed2c:d0ca:4a9:689f%eno1]:22000-[fe80::1260:4bff:fe5c:5be6%eno1]:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-62TFGJHHV7K6KU5H9ECC8ROP7Q: Syncthing is being stopped (0 remain)
[MBF5Y] 2025/08/20 11:27:17 INFO: Connection to PDJKYGZ at [fe80::ed2c:d0ca:4a9:689f%eno1]:22000-[fe80::1260:4bff:fe5c:5be6%eno1]:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-62TFGJHHV7K6KU5H9ECC8ROP7Q closed: Syncthing is being stopped
[MBF5Y] 2025/08/20 11:27:17 INFO: Lost primary connection to 5GIHYCJ at [2806:290:c80a:c7b4:e368:c3f4:6840:4991]:22000-[2806:290:c80a:c7b4:d88d:a699:2471:3684]:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-62TFGJHI5T41AI3JKG6O0OT48A: Syncthing is being stopped (0 remain)
[MBF5Y] 2025/08/20 11:27:17 INFO: Connection to 5GIHYCJ at [2806:290:c80a:c7b4:e368:c3f4:6840:4991]:22000-[2806:290:c80a:c7b4:d88d:a699:2471:3684]:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-62TFGJHI5T41AI3JKG6O0OT48A closed: Syncthing is being stopped
[MBF5Y] 2025/08/20 11:27:17 INFO: Lost primary connection to ERQIOVL at [fe80::ed2c:d0ca:4a9:689f%eno1]:22000-[fe80::42b0:34ff:fe1e:d462%eno1]:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-62TFGJHHJACPGI0AGGNMQ1OLPK: Syncthing is being stopped (0 remain)
[MBF5Y] 2025/08/20 11:27:17 INFO: Connection to ERQIOVL at [fe80::ed2c:d0ca:4a9:689f%eno1]:22000-[fe80::42b0:34ff:fe1e:d462%eno1]:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-62TFGJHHJACPGI0AGGNMQ1OLPK closed: Syncthing is being stopped
[MBF5Y] 2025/08/20 11:27:17 INFO: Lost primary connection to NCKRCV3 at [fe80::ed2c:d0ca:4a9:689f%eno1]:22000-[fe80::ca94:2ff:fe81:1a9f%eno1]:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-62TFGJIEBMCF826ANUJVO4L2RG: Syncthing is being stopped (0 remain)
[MBF5Y] 2025/08/20 11:27:17 INFO: Connection to NCKRCV3 at [fe80::ed2c:d0ca:4a9:689f%eno1]:22000-[fe80::ca94:2ff:fe81:1a9f%eno1]:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-62TFGJIEBMCF826ANUJVO4L2RG closed: Syncthing is being stopped
[MBF5Y] 2025/08/20 11:27:17 INFO: Lost primary connection to 2RZZ2AZ at 192.168.1.70:22000-192.168.1.66:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-62TFGJHLM9RM6DFQD9CK4QT32M: Syncthing is being stopped (0 remain)
[MBF5Y] 2025/08/20 11:27:17 INFO: Connection to 2RZZ2AZ at 192.168.1.70:22000-192.168.1.66:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-62TFGJHLM9RM6DFQD9CK4QT32M closed: Syncthing is being stopped
[MBF5Y] 2025/08/20 11:27:17 INFO: TCP listener ([::]:22000) shutting down
[MBF5Y] 2025/08/20 11:27:18 INFO: Exiting
There’s a lot to unpack here, so a few points/pointers;
The version packaged in Debian is buggy. You appear to have found a working one, good.
By default there is no authentication for a new install. Perhaps you have an old install with credentials from before?
By default Syncthing doesn’t log to the file you mentioned, so if you’re doing something special to launch Syncthing it might be relevant to explain that.
The log snipped doesn’t show whatever was the login problem, which presumably happened earlier.
