I’m trying to generate proto for the very first time. Everything is done under Windows and Go v1.17.
I get stuck on the following error:
go run build.go proto
go get: installing executables with 'go get' in module mode is deprecated.
To adjust and download dependencies of the current module, use 'go get -d'.
To install using requirements of the current module, use 'go install'.
To install ignoring the current module, use 'go install' with a version,
like 'go install example.com/cmd@latest'.
For more information, see https://golang.org/doc/go-get-install-deprecation
or run 'go help get' or 'go help install'.
HEAD is now at b03c65ea skippy peanut butter
Formatting database.proto
cmd\stdiscosrv\database.go:8: running "protoc": exec: "protoc": executable file not found in %PATH%
exit status 1
exit status 1
Obviously, I need to have the protoc (or protoc.exe) binary, but where should I get/compile it from? I’ve only managed to find https://github.com/protocolbuffers/protobuf, but trying to use the precompiled binary from there results only in a mass of errors.
