I can’t quite figure out why Syncthing is using so much bandwidth. Perhaps you can help me. I have an UnRAID server, and when I pause the Syncthing docker, network usage is essentially zero. Then when I start the server, network usage sustains download at about 500Kbps. This is unexpected to me, as I set the incoming rate limit to 50 KiB/s.
Is there any way to see what is using so much bandwidth on Syncthing? Last month, this caused my server to use more than the 2TB of data allowance my ISP provides me. This is why I set the incoming rate limit so low. Thank you in advance for any support!!
2022-04-18 22:54:59 My ID: 4BMU7PB-MGYDGPC-ACPZWHA-UM2CFTN-WNF7S6U-N2CS3K6-ANYFHUJ-X6E7MA7
2022-04-18 22:55:00 Single thread SHA256 performance is 339 MB/s using minio/sha256-simd (339 MB/s using crypto/sha256).
2022-04-18 22:55:00 Hashing performance is 283.54 MB/s
2022-04-18 22:55:00 Overall send rate is unlimited, receive rate limit is 50 KiB/s
2022-04-18 22:55:00 Rate limits do not apply to LAN connections
2022-04-18 22:55:00 Using discovery mechanism: global discovery server https://discovery.syncthing.net/v2/?noannounce&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
2022-04-18 22:55:00 Using discovery mechanism: global discovery server https://discovery-v4.syncthing.net/v2/?nolookup&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
2022-04-18 22:55:00 Using discovery mechanism: global discovery server https://discovery-v6.syncthing.net/v2/?nolookup&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
2022-04-18 22:55:00 Using discovery mechanism: IPv4 local broadcast discovery on port 21027
2022-04-18 22:55:00 Using discovery mechanism: IPv6 local multicast discovery on address [ff12::8384]:21027
2022-04-18 22:55:00 …
2022-04-18 22:55:00 TCP listener ([::]:22000) starting
2022-04-18 22:55:00 Relay listener (dynamic+https://relays.Syncthing.net/endpoint) starting
2022-04-18 22:55:00 Ready to synchronize “Media” (wq76k-9ztfj) (receiveonly)
2022-04-18 22:55:00 QUIC listener ([::]:22000) starting
2022-04-18 22:55:00 GUI and API listening on [::]:8384
2022-04-18 22:55:00 Access the GUI via the following URL: http://127.0.0.1:8384/
2022-04-18 22:55:00 My name is “9 Arrowhead”
2022-04-18 22:55:00 Device DXJYZRX-LNU5C22-IDE64DR-QPQMV6Y-FAJ7CH6-AVIJQSE-D7ESVCI-HVHCEQJ is “3 Hyde St” at [dynamic]
2022-04-18 22:55:11 Established secure connection to DXJYZRX-LNU5C22-IDE64DR-QPQMV6Y-FAJ7CH6-AVIJQSE-D7ESVCI-HVHCEQJ at 172.17.0.2:60156-38.145.211.217:22067/relay-client/TLS1.3-TLS_AES_128_GCM_SHA256
2022-04-18 22:55:11 Device DXJYZRX-LNU5C22-IDE64DR-QPQMV6Y-FAJ7CH6-AVIJQSE-D7ESVCI-HVHCEQJ client is “Syncthing v1.18.1” named “3 Hyde” at 172.17.0.2:60156-38.145.211.217:22067/relay-client/TLS1.3-TLS_AES_128_GCM_SHA256
2022-04-18 22:55:14 Detected 1 NAT service
2022-04-18 22:55:16 Completed initial scan of receiveonly folder “Media” (wq76k-9ztfj)
2022-04-18 22:55:20 quic://0.0.0.0:22000 detected NAT type: Port restricted NAT
2022-04-18 22:55:20 quic://0.0.0.0:22000 resolved external address quic://70.187.140.30:22000 (via stun.syncthing.net:3478)
2022-04-18 22:56:05 Joined relay relay://144.172.118.81:22067
