Hi
I’m trying to upgrade the OpenBSD package to v2, but there’s a build error I don’t understand. Maybe someone with Go knowledge will know what it means.
lib/syncthing/globalmigrations.go:10:2: code in directory /usr/ports/pobj/syncthing-2.0.12/go/src/github.com/syncthing/syncthing/internal/db expects import "github.com/syncthing/syncthing/internal/db/sqlite"
The ongoing discussion on the ports mailing list can be found here.
Build log
+++ Tue Dec 23 11:01:03 -03 2025
===> Patching for syncthing-2.0.12
===> Applying OpenBSD patch patch-build_go
Hmm... Looks like a unified diff to me...
The text leading up to this was:
|Print build commands
|Index: build.go
|--- build.go.orig
|+++ build.go
Patching file build.go using Plan A...
Hunk #1 succeeded at 532.
done
===> Applying OpenBSD patch patch-cmd_syncthing_main_go
|use unveil(2) to limit execution to
|- restarting itself
|- xdg-open(1) aka. to open the web interface
|Index: cmd/syncthing/main.go
|--- cmd/syncthing/main.go.orig
|+++ cmd/syncthing/main.go
Patching file cmd/syncthing/main.go using Plan A...
Hunk #1 succeeded at 31.
Hunk #2 succeeded at 215.
done
===> Applying OpenBSD patch patch-lib_build_build_go
|Disable phone-home calls / anonymous usage reporting
|Index: lib/build/build.go
|--- lib/build/build.go.orig
|+++ lib/build/build.go
Patching file lib/build/build.go using Plan A...
Hunk #1 succeeded at 83.
done
===> Compiler link: clang -> /usr/bin/clang
===> Compiler link: clang++ -> /usr/bin/clang++
===> Compiler link: cc -> /usr/bin/cc
===> Compiler link: c++ -> /usr/bin/c++
===> Generating configure for syncthing-2.0.12
===> Configuring for syncthing-2.0.12
===> Building for syncthing-2.0.12
cd /usr/ports/pobj/syncthing-2.0.12/go/src/github.com/syncthing/syncthing && /usr/bin/env -i GOMAXPROCS=1 GO386=softfloat GOCACHE="/usr/ports/pobj/syncthing-2.0.12/go-cache" GOTOOLCHAIN=local TMPDIR="/usr/ports/pobj/syncthing-2.0.12/build-amd64" GOPROXY=invalid://ports.should.not.fetch.at.buildtime/ GO111MODULE=off GOPATH="/usr/ports/pobj/syncthing-2.0.12/go:/usr/local/go-pkg" PORTSDIR="/usr/ports" LIBTOOL="/usr/bin/libtool" PATH='/usr/ports/pobj/syncthing-2.0.12/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/X11R6/bin' PREFIX='/usr/local' LOCALBASE='/usr/local' X11BASE='/usr/X11R6' CFLAGS='-O2 -pipe' TRUEPREFIX='/usr/local' DESTDIR='' HOME='/syncthing-2.0.12_writes_to_HOME' PICFLAG="-fpic" BINGRP=bin BINOWN=root BINMODE=755 NONBINMODE=644 DIRMODE=755 INSTALL_COPY=-c INSTALL_STRIP= MANGRP=bin MANOWN=root MANMODE=644 BSD_INSTALL_PROGRAM="/usr/ports/pobj/syncthing-2.0.12/bin/install -c -m 755" BSD_INSTALL_SCRIPT="/usr/ports/pobj/syncthing-2.0.12/bin/install -c -m 755" BSD_INSTALL_DATA="/usr/ports/pobj/syncthing-2.0.12/bin/install -c -m 644" BSD_INSTALL_MAN="/usr/ports/pobj/syncthing-2.0.12/bin/install -c -m 644" BSD_INSTALL_PROGRAM_DIR="/usr/ports/pobj/syncthing-2.0.12/bin/install -d -m 755" BSD_INSTALL_SCRIPT_DIR="/usr/ports/pobj/syncthing-2.0.12/bin/install -d -m 755" BSD_INSTALL_DATA_DIR="/usr/ports/pobj/syncthing-2.0.12/bin/install -d -m 755" BSD_INSTALL_MAN_DIR="/usr/ports/pobj/syncthing-2.0.12/bin/install -d -m 755" go run build.go -version v2.0.12 -no-upgrade install syncthing
2025-12-23 11:01:41 INF exit status 1
exit status 1
*** Error 1 in . (Makefile:38 'do-build')
*** Error 2 in . (/usr/ports/infrastructure/mk/bsd.port.mk:3063 '/usr/ports/pobj/syncthing-2.0.12/build-amd64/.build_done': @cd /usr/ports/n...)
*** Error 2 in /usr/ports/net/syncthing (/usr/ports/infrastructure/mk/bsd.port.mk:2710 'build': @lock=syncthing-2.0.12; export _LOCKS_HELD=...)
--- Tue Dec 23 11:01:42 -03 2025
Ports diff
Index: Makefile
RCS file: /cvs/ports/net/syncthing/Makefile,v
diff -u -p -r1.73 Makefile
--- Makefile 22 Jul 2025 20:20:25 -0000 1.73
+++ Makefile 23 Dec 2025 14:06:16 -0000
@@ -1,6 +1,6 @@
COMMENT = open decentralized synchronization utility
-V = 1.30.0
+V = 2.0.12
DISTNAME = syncthing-${V}
DISTFILES = syncthing-source-v${V}${EXTRACT_SUFX}
Index: distinfo
RCS file: /cvs/ports/net/syncthing/distinfo,v
diff -u -p -r1.50 distinfo
--- distinfo 4 Jul 2025 19:19:39 -0000 1.50
+++ distinfo 23 Dec 2025 14:06:16 -0000
@@ -1,2 +1,2 @@
-SHA256 (syncthing-source-v1.30.0.tar.gz) = 7xvnHGZ1PAQhKrHJxUjmeNRoutmNxUYeg1QKTvXC/Lo=
-SIZE (syncthing-source-v1.30.0.tar.gz) = 16142834
+SHA256 (syncthing-source-v2.0.12.tar.gz) = VgBK5tl0qjh8PGpzTrmKr9XWFZ/GV6H0xhjgsYFPra4=
+SIZE (syncthing-source-v2.0.12.tar.gz) = 62613260
Index: patches/patch-build_go
RCS file: /cvs/ports/net/syncthing/patches/patch-build_go,v
diff -u -p -r1.24 patch-build_go
--- patches/patch-build_go 4 Jun 2025 20:07:43 -0000 1.24
+++ patches/patch-build_go 23 Dec 2025 14:06:16 -0000
@@ -3,7 +3,7 @@ Print build commands
Index: build.go
--- build.go.orig
+++ build.go
-@@ -549,7 +549,7 @@ func appendParameters(args []string, tags []string, pk
+@@ -532,7 +532,7 @@ func appendParameters(args []string, tags []string, pk
if !debugBinary {
// Regular binaries get version tagged and skip some debug symbols
Index: patches/patch-cmd_syncthing_main_go
RCS file: /cvs/ports/net/syncthing/patches/patch-cmd_syncthing_main_go,v
diff -u -p -r1.3 patch-cmd_syncthing_main_go
--- patches/patch-cmd_syncthing_main_go 15 Jun 2025 16:42:21 -0000 1.3
+++ patches/patch-cmd_syncthing_main_go 23 Dec 2025 14:06:16 -0000
@@ -5,8 +5,8 @@ use unveil(2) to limit execution to
-@@ -29,6 +29,8 @@ import (
- "syscall"
+@@ -31,6 +31,8 @@ import (
+ "text/tabwriter"
"time"
+ "golang.org/x/sys/unix"
@@ -14,23 +14,28 @@ Index: cmd/syncthing/main.go
"github.com/alecthomas/kong"
"github.com/gofrs/flock"
"github.com/thejerf/suture/v4"
-@@ -206,6 +208,19 @@ func defaultVars() kong.Vars {
+@@ -213,6 +215,24 @@ func defaultVars() kong.Vars {
func main() {
+ // Create a parser with an overridden help function to print our extra
+ // help info.
+ if err := unix.Unveil("/", "rwc"); err != nil {
+ panic(err)
+ if err := unix.Unveil("/usr/local/bin/syncthing", "rx"); err != nil {
+ panic(err)
+ if err := unix.Unveil("/usr/local/bin/xdg-open", "rx"); err != nil {
+ panic(err)
+ if err := unix.UnveilBlock(); err != nil {
+ panic(err)
- // First some massaging of the raw command line to fit the new model.
- // Basically this means adding the default command at the front, and
- // converting -options to --options.
+ var entrypoint CLI
+ parser, err := kong.New(
+ &entrypoint,
Index: patches/patch-lib_build_build_go
RCS file: /cvs/ports/net/syncthing/patches/patch-lib_build_build_go,v
diff -u -p -r1.4 patch-lib_build_build_go
--- patches/patch-lib_build_build_go 28 Nov 2024 11:47:47 -0000 1.4
+++ patches/patch-lib_build_build_go 23 Dec 2025 14:06:16 -0000
@@ -3,7 +3,7 @@ Disable phone-home calls / anonymous usa
-@@ -74,7 +74,7 @@ func setBuildData() {
+@@ -83,7 +83,7 @@ func setBuildData() {
exp := regexp.MustCompile(`^v\d+\.\d+\.\d+(-[a-z]+[\d\.]+)?$`)
IsRelease = exp.MatchString(Version)
Current Makefile
V = 2.0.12
CATEGORIES = net
HOMEPAGE = https://syncthing.net/
MAINTAINER = Edd Barrett <edd@openbsd.org>, \
Klemens Nanni <kn@openbsd.org>
# MPL 2.0
PERMIT_PACKAGE = Yes
# uses unveil()
WANTLIB += c pthread
SITES = https://github.com/syncthing/syncthing/releases/download/v${V}/
WRKDIST = ${WRKDIR}/syncthing
WRKSRC = ${WRKDIR}/go/src/github.com/syncthing/syncthing
MODULES = lang/go
MODGO_TYPE = bin
# Syncthing contains a lot of stuff that end users wouldn't be interested in,
# so we package only these binaries.
ST_CMDS = syncthing stdiscosrv strelaysrv
MAKE_ENV = GOMAXPROCS=${MAKE_JOBS}
# If at any point quic is busted for our in-tree go version, then you can
# temporarily add `-tags noquic` to at least get syncthing building (albeit
# without quic support obviously). When you do that, some more tests will fail.
do-build:
.for cmd in ${ST_CMDS}
cd ${WRKSRC} && ${MODGO_CMD} run build.go -version v${V} \
-no-upgrade install ${cmd}
.endfor
# Connections test hangs and times out. This doesn't appear to interfere with
# day-to-day running of Syncthing though.
# https://github.com/syncthing/syncthing/issues/8421
do-test:
cd ${WRKSRC} && ${MODGO_CMD} run build.go test
do-install:
${INSTALL_PROGRAM} ${WRKSRC}/bin/${cmd} ${PREFIX}/bin/
.endfor
.for sec in 1 5 7
${INSTALL_MAN} ${WRKSRC}/man/*.${sec} ${PREFIX}/man/man${sec}/
.endfor
.include <bsd.port.mk>
syncthing.tar.gz (4.3 KB)
