Appdata synced without issues, but on my big data folder it has been stuck for a few hours now, restarting the service did not help either.
I am confused why it marks the device as “Up to Date” as well…
Need more of the log, but from what’s shown, there are at least a couple of issues…
Seems important, but I don’t know enough about it to offer additional input.
You have a syntax problem in the Sync Protocol Listen Addresses field. It’s supposed to be in URI format: quic://0.0.0.0:22000
The retry timer above explains the extended delay.
Device BA2RCUU has a network or some other issue because it didn’t respond before timing out and then finally succeeding:
Besides the networking issues above, a relatively large number of files and directories + encrypting files + multiple hosts syncing to 6CQVVE puts a lot of load on 6CQVVE.
5HJMFO/elephant-arch can say “Up to Date” because it’s only one of multiple hosts syncing with 6CQVVE. For example, if “Butterfly” is out of sync, 6CQVVE could be preparing to send it changes received earlier by “elephant-arch”. Also, every time Syncthing is restarted on 6CQVVE it needs to scan everything again to see if anything changed while it was offline. Restarting multiple times usually increases the sync time rather than speeding it up.
