Dear All,
My current set up is using a radio an IP radio link between two NAS drives, I have 3 syncthing folders to which data is stored on NAS 1 Then synthing is to sync them to the respective folders on NAS 2 All the folders work and data is transferred
2 of my folders take ages to sync. So I stopped them to test the speed, I managed to copy 1.5gb of data across the radio link within 8 mins using one folder within syncthing Now if I try the other folders they seam to be really slow and I’ve been transferring from another folder 30gb of data for the last 12 hours - why is it so slow?
My overall aim is to have several streams of syncthing folder to folder set up so I can transfer data I split the folders so if my data link bandwidth became too congested I could then manually pause folders
Any suggestions or help regarding my issue would be very much appreciated!
Can share more details regarding setup if needed
Regards Tom
