doesn't work when not on the same wifi
It seems like my syncthing is not working when not all devices are on the same wifi, could it be, or I’m missing something? (i’m using mobile wifi too - but I enabled it on settings)
Can you post screenshots of the Syncthing Web GUI from all devices? If this is Android, you can access the Web GUI from the left slide-out menu. Also, please make sure to include all information that is visible under “This Device”.
In addition, if you’ve modified any of the default settings, especially those that could affect connectivity like discovery or listeners, please list those modifications too.
