Doesn't sync with untrusted device
Syncthing for Windows version 2.0.15 on all devices.
An utrusted device shares a folder with trusted device. In untrusted device’s web interface both in folders and in remote devices I see green “Up to Date” and everything is fine. 194 files and 41 directories both local and global state. There is one more trusted device in local network near the untrusted device. In untrusted device’s web interface I decide to share the folder with the second trusted device and set it for sharing. On the second trusted device’s web interface I add the folder, enter the password, enter the path to an empty folder, set “Folder Type” to “Receive Only” and press Save. It first starts syncing but then displays “Out of Sync”. 193 Out of Sync Items and 193 Failed Items. I click failed items and I see “syncing: finishing: pull: no such file” for all files. I wait and nothing changes. In the log I see message “WRN Failed to sync” and the same “syncing: finishing: pull: no such file”. In the untrusted device’s web interface in Remote Devices section - 193 Out of Sync Items.
What do I do from now?
Actual, full errors?
