$ go get github.com/calmh/syncthing/cmd/syncthing
Currently requires Go v. 1.2, e.g. v. 1.2.2, which is available at: http://golang.org/dl/ It does not work with Go v.1.3 at the moment.
Huh? Why not? I don’t specifically “go get” very often, but all the releases are compiled with Go1.3 or a devel version slightly newer than 1.3.
Argh. The log is now gone. I’ll reproduce the error. Something about incompatible static libraries I believe. (… library … 1.2.1.a … while your system … 1.3.0…)
Ah. That’s most likely that you have libraries compiled with go1.2 around that the go1.3 compiler doesn’t like and isn’t smart about rebuilding. rm -r ~/pkg fixes that.
