Hello! After suffering data loss, hair loss, and weight loss with Bittorrent Sync, I decided there is nothing better than free software! And I was not wrong, Synthing is more powerful than btsync, as expected! But I seem to have found a bug, or my configuration is not right yet…
This is how I setup Syncthing on my laptop: I installed Syncthing 0.11.26 from the official APT repository on Debian Wheezy, run the command syncthing
, and set the default folder to Staggered File Versioning and to download in Alphabetic order.
In the Android device, I installed the latest version from the Play Store, and configured it to always run in the background, set the notification priority to normal, and enabled advanced folder selection. Then I created a new folder named Sync, and set its ID to default. On Android I did _not_ enable File Versioning.
On both sides I added the devices with the default options (metadata compression, dynamic address, not observer).
Then in the laptop, I copied a text file named File.json to ~/Sync/. It later appeared in the Android device. Then I opened File.json in Android, and edited it with the ES File Explorer, adding a few words to it. I waited to see if it would sync, but it did not. So I told Syncthing on both devices to refresh, but still the edited file remained only in the Android device. Then I copied another file to the Sync directory in Android, and only then Syncthing really synced, including the new File.json I had edited with ES File Explorer.
So the problem I seem to be suffering is that it doesn’t always sync, and it was in my first use. In the WebGUI on the laptop, I see the option “Ignore Permissions: File permission bits are ignored when looking for changes. Use on FAT file systems.”. I don’t know if I should enable this, since I see this option in the laptop, which has a ext4 filesystem, but not in the Android device. Is this option related to this problem?
