I’m in the process of documenting the behaviour of -reset-database.
I’m concerned that documenting the behaviour of a potentially dangerous side effect may not be the right long-term course of action. I’m still happy to do it in the short term, if it’s deemed appropriate though.
I have a few concerns with -reset-database or its REST equivalent:
- It doesn’t follow the principle of least astonishment
- It sounds like it only changes the database, but it changes sync folders also
- It creates a
.stfolderif one doesn’t exist in a sync folder- This could be very bad where a sync folder is an unmounted external drive, filling up a laptop’s small internal disk
- If the external disk is mounted later, it will then mask the data written to the internal disk
Wouldn’t it be better to:
- Not create
.stfolders - Only scan / update the database for the folders which syncthing has marked as it’s own (ie,
.stfolderexists) - Update the documntation of
-reset-databaseto say:Reset the database, forcing a full rescan and resync of all currently available sync folders.
