Docker Syncting external path
Hello and good evening, I have a problem that I’m not getting anywhere with.
Currently I am using Syncthing under Windows and synchronize my files from different computers externally to a NAS. That means I have NO files locally under Windows. I only use Windows to run Syncthing.
Now I would like to move Syncthing to Docker (PhotonOS) and build it identically. Unfortunately it is not possible to synchronize Syncthing only to the NAS. It always creates a folder under _data and synchronizes to the Docker host volume.
How would I have to mount my NAS in syncthing to do this?
Maybe someone has an idea. Thanks.
Greetings
OK, while I was also waiting for my question to be approved, I came up with a solution myself. My previous approach was always to use volume mounts. Now I use a Bind mount and can mount everything I want with it.
So I have my functionality again.
Greetings
